Wraparound seat/extra storage and cup holders
  • dscoff
    • Jul 2013
    • 22
    • Port Coquitlam BC
    • 2003 SANTE 210
    When my wife and I surf without other adults in our '03 210 (our kids aren't ballast size yet) we usually place two 400lb FlyHigh sacs on the rear seat and port seat. This creates an awesome wave, but blocks access to the storage under that seat and the four cup holders behind it.
    After checking out Jeff's and other's wrap around seat projects I decided this would be a good solution ie filling the gap behind the driver's seat with something useful. Truthfully I spent a few outings just checking out if we inadvertently used that area for anything, but usually nothing more than a cooler or snack bag tossed there.
    I measured the port cup holders (diameter and spacing) so the sides would look symmetrical, and measured the space so if I add a cushion later it'll be the same height as the factory ones, and so there was ample room for driver's seat movement.
    I used non-marine 5/8 ply for the structure, glued with PL Premium and screwed with 2" #8 screws. Pretty sure you could bolt an outboard to this
    Initially I'd planned on first coating everything with polyester resin to waterproof, then finish the outside with gloss white gel coat and worry about finding grey outdoor carpet at a later date. This is why in this first photo the outer surfaces have polyester filler on them. Literally the day after I'd filled and sanded all the sides, I found perfect grey outdoor carpet at Home Depot. Other than a nice smooth surface for the carpet to adhere to, that was a couple of pointless hours of sanding.
    Since I'd used unwaxed resin for the waterproofing coat, I still had to finish it with waxed gel coat before upholstering. I've upholstered the top, bottom, front and back, and the sides are drying as I type (carpet also glued with PL Premium).
    Should be ready for the boat tomorrow, as I'm going to steal four cup holders from the bow until new ones arrive from NP.
  • dscoff
    • Jul 2013
    • 22
    • Port Coquitlam BC
    • 2003 SANTE 210
    Done! Lid carpeted, remaining cup holders in and lid pull installed.
    I might see if I can get a cushion made to match the port side, or even one with the "behind the knee" detail facing the bow so it's more of a lounge extension to the rear seat. That can wait... Time to surf!
      I have found that if you use unwaxed polyester resin, the carpet will stick to whatever the resin is on.
      • dscoff
        • Jul 2013
        • 22
        • Port Coquitlam BC
        • 2003 SANTE 210
        Good to know! Be nice to skip the gel coat next time. I wasn't sure how the adhesive and unwaxed layer would behave together (visions of a never-curing slimy mess).
        • bscott
          • 188
          • Bolingbrook, IL
          Looks good! Be sure to post pics when it is finished and in the boat.
          • dscoff
            • Jul 2013
            • 22
            • Port Coquitlam BC
            • 2003 SANTE 210
            Carpet's not an exact match, but close enough for me.
            • dscoff
              • Jul 2013
              • 22
              • Port Coquitlam BC
              • 2003 SANTE 210
              There are days when I wish those cupholders were filled with coconut tanning oil and Smirnoff Ice's, but truthfully, I have a 2 and 5 year old who LOVE being on the boat, which is a win now and going to be amazing when they can surf (and more importantly drive).
              • gome123
                • Apr 2014
                • 199
                • ID
                • 2005 SAN 210 Team
                By having Sippies on your boat just makes it that much cooler!!! I always carry a pink sippy with elephants and a green one with cartoons. My 14 month old daughter loves to drive the boat and bounces to music.
