Cocktail Table install
  • jonnydeez
    • Mar 2015
    • 46
    • Austin
    • 2007 Super Air Nautique 220 Team Edition
    I wanted to add a table, but did not want to cut into the floor, so I went with a side mount table from Garelick. Install went pretty quickly.
    Kit comes with Table top, Leg and Mount.
    Find location you want to mount and use painters tape to mask the desired area. Place a level on the location, and draw horizontal and vertical lines.
    Mark location of holes using the supplied Mount.
    Drill holes through boat fiberglass and backing plate. You will have to supply your own backing plate. I used some Polypropylene that I had laying around for the backing plate.
    Install the Mount with Stainless Steel Screws, Washers, and Nyloc Nuts. Use stainless on everything so it does not rust.
    Check for level again before fully tightening. Tighten when completely level.
    Install Leg.
    Install Table top.
    Enjoy!
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    Nice that looks money
