I've been wanting to do this mod for a LONG time now and finally got around to it! For those of you that don't know... under the driver's dash of I guess all OG210s (for sure 2002-2006) is a false wall that the heater is hidden behind, circuit breaker panel, and one 6.5" speaker is mounted. Holding this false wall in place is a "hump" made into the floor that the wall rests against and held into place with some screws. There is a decent amount of space behind the wall for wiring, hoses, etc and this wall could be moved further toward the bow if the "hump" wasn't there making more room for things like sub enclosures! My enclosure is a design I downloaded from WetSounds website years ago and built last season with a Sundown Audio SA-12 installed in it... It sounds really good compared tony old enclosure! For reference the enclosure is 15" tall, 20" wide, and 14.75" deep with a 4" Precision Port tuned about 40hz. That brings me to the purpose of this thread because I haven't found much DIY on removing said "hump"... So bring on the pictures!!!
This is the troublesome "Hump"
You can see the holes made by the screws that hold the false wall in place.
I have found with other projects that a Ridgid JobMax is the best tool for cutting the fiberglass on these boats which is insanely strong! So I got to cutting up my perfectly good boat again!
She gone!
There was a void left in the hull where factory foam didn't quite fill up... I later found an old roll of masking tape hidden in the void between the hull and deck.
This was the void.
I filled the void with some foam and let it cure, then cut it back down flat.
I then added a piece of 1/8" HDPE just to give an even surface to layer fiberglass onto and add a bit of strength after cutting it to the shape of the hole... Here is the HDPE.
After a few layers of fiberglass mat it's sealed up, but I'm not real happy with it. It's not quite as flat as I wanted so I will add some more to even it out with the rest of the deck surface.
It was far enough along I thought so I decided to mock the enclosure back into place to check fitment and see how much space I've gained, as well as figure out where to mount the circuit breaker panel, speaker, and PP box. I will add some carpet in the place where the "hump" used to be.
I've gained roughly 8.5" of space from where the enclosure used to sit... The faint line between my feet is the indent from the enclosure feet which are 2" further back on the bottom... So imagine that line 2" towards my heels. For reference my heels are against the seat base and that's a size 11 shoe. I basically straddled the enclosure last season!
I'll have more pics of the progress once I finish the floor hopefully this weekend.
She gone!
This was the void.
