DIY Perfect Pass fix- dim screen /blank screen
  • biacs
    • Aug 2020
    • 252
    • IL
    • 2006 Nautique 220 Team Edition
    Hi all,
    This is to remedy moisture buildup in the perfect pass gauge. If all else fails I’ll plunk down the cash for the stargazer model.
    I used tuck tape to seal the back, the silicon spray to coat the board, and silica packets to make sure the interior of the gauge stays dry. Also I added some vents in my boat cover. The boat sits outside on occasion.
    I attempted to superglue some of the packets but they seem pretty slick and wouldn’t take to the inside of the gauge.
    Should be sealed uptight this tape does NOT let go. And the silica should hopefully do the trick.
    Tuck Tape Construction Grade... https://www.amazon.com/dp/B01N6L7FK0...p_mob_ap_share
    MG Chemicals - 422B-340G 422B... https://www.amazon.com/dp/B008O9YGQI...p_mob_ap_share
    Dry & Dry 2 Gram [50 Packets] Premium Pure Silica Gel Packets Desiccant Dehumidifier - Food Safe Rechargeable Silica Gel Packs https://www.amazon.com/dp/B00DYLUWVO..._BJzsV2oolstOc
  • biacs
    • Aug 2020
    • 252
    • IL
    Been using it for about five hours so far. Perfect pass is working fine no issues!
    Will know in a few more weeks how the heat and humidity under the cover may or may not affect the fix.
    The boat is typically stored inside but occasionally I’ll leave it covered out at the lake.
    • daveybobcat
      • Aug 2019
      • 33
      • Palau
      • 2006 sante 220
      This is amazing! Thank you so much!!!
      • biacs
        • Aug 2020
        • 252
        • IL
        Just checking in on the first month.
        Probably about 15 hours on the boat and the perfect pass is still working 100%!
        • MN Ryan
          • Aug 2020
          • 1250
          • Maple Grove, MN
          • 2007 SV-211 TE
          biacs So, what's the process for getting the gauge out of the dash?
          • biacs
            • Aug 2020
            • 252
            • IL
            Originally posted by MN Ryan View Post
            biacs So, what's the process for getting the gauge out of the day?
            Overall process from memory:
            Remove the top dash screws and thumbscrew
            Remove audio control drip metal brace- screws in behind
            Pull dash panel forward for access
            Perfect pass is held from behind w nut as I recall w a bracket across the back.
            It was painful fist time, now it’s 3 minutes to pop off :-)
            2006 SANTE - Bull in a China Shop - Central IL
