dy9213, thanks for the post. Yeah, I do a lot of DIY electronics so I'm pretty used to soldering small SMT caps. But I "get" that might not be for everyone. I probably should have filmed that part of the procedure. My general approach is:
- Heat up one side of the old part and once the solder is melted lift that side of the part up with small screwdriver/tweezers or whatever. Heat up the other side and remove the old part (tweezers, needle nose pliers, etc.).
- Important - clean up the 2 pads first before installing the new part. I like to use the braided solder wick stuff like - https://www.amazon.com/Lesnow-No-Cle...dDbGljaz10cnVl
- Then put a blob of solder on ONE of the pads. Cover the entire pad but only about 1mm high. You want that blob to be smooth and uniform and not "pointy". That will make it easier to place the part.
- Place the new surface mount capacitor and hold the top with tweezers/ice pick, etc. Heat up the side with the solder to "lock it down".
- Heat up the other side, both pad and capacitor together. Apply solder. You should have a nice arc of solder from the edge of the pad to the top of the capacitor.
- You may want to heat up and apply solder to the other side just to clean it up.
- If you have a multimeter make sure you haven't shorted the pads together AND that there is continuity between the capacitor and the trace that it's connected too.
