I have a 2006 Nautique 210 and looking to update my gauges. Like many of you, I have been on the waitlist for the Faria Gateway conversion kit, and still waiting. All of my gauges work, but after 17 years they are showing their age. See below
After almost a year of looking for the original gauges or someone to refurbish them, I came across these gauges below from SkiBoatPartsOnline.com and ordered a set. Medallion Conversion Kit - Correct Craft - TRD-2001-CC
TRD - Medallion Conversion kit to replace the Medallion MDC controlled gauges to a conventional instrument package and a more accurate GPS speedometer.
Available in Black or White.
DESIGNED FOR BOATS WITH EXISTING PERFECT PASS SPEED CONTROL
TRD Conversion kit to replace the Faria / Gateway controlled gauges to conventional TRD analog gauges (except speedo, this is a GPS speedo)
BASIC REPLACEMENT KIT - does not include the depth or water temp/air temp (this can be achieved by adding an optional 2" depth finder w/ temps)
Kit Includes: (1) TRD 5" GPS Speedometer, (1) 5" TRD Tach w/ hrs, (1) 2" TRD Voltmeter, (1) 2" TRD Oil Pres., (1) 2" TRD Temp., (1) TRD Fuel gauge, custom wire harness with back-lighting color selection between Red or White, and a solid state time delay relay to conserve battery power, multi-pin easy plug connections at gauges, Connector for Check Eng. Light, Connections for 12v outlet, 2 Year Limited Warranty.
The kit was very easy to install and all plug and play. The gauges have a locking collar that holds the new gauges firmly in place. In my opnion, a much better design than the Faria ones. Take a look below.
Wiring harness install.
What a difference from old to new, and no more Faria Gateway Box.
Ron answered all of my questions, and Sara was a pleasure to deal with on the phone.
Check them out online at skiboatpartsonline.com or give them a call, you wont regret it.
