Oil Change Kit
  • pauldixon
    • Oct 2022
    • 26
    • British Columbia
    • 2014 SN 200 Team OB 6.0L
    Oil Change Kit
    This is the best setup for oil changes I have seen, I highly recommend this. No tools and oil changes, including transmission can be done in less than 15min total. See attachment including links and snips below:
  • bturner
    • Jun 2019
    • 1576
    • MI
    • 2016 200 Sport Nautique
    I like the concept of the quick connects. Do you have the links to the fittings you used or the specs?
    • pauldixon
      • Oct 2022
      • 26
      • British Columbia
      I just took some stuff down to the local fitting store and had them size based on it. If you take down the hose cap and both sizes of hose you’ll get everything you need. I’d use a 3/8” quick connect and make sure you don’t use one for a pressure washer as they have silicone seals which expand after contact with oil and won’t work
      • machyy1
        • Nov 2024
        • 18
        • Topsfield MA
        I really like that cup idea, that is great, thank you
        • BasaltRMK
          • Apr 2020
          • 282
          • Basalt, CO
          • 2024 SAN G23 2020 SAN G21 (Sold) 2018 SAN G21 (Sold) 2015 Tigé R20 (sold) 1972 MFG Gypsy-15 Tri-hull (sold)
          The quick-connects are key. I can look up what I ordered on Amazon if you need it, I purchased a new male fitting for my 2024 G this summer to match what I already had on the extractor for the previous boat. Likewise, I love the idea of the filter oil catch tub.
          There's a good sticky thread on this setup in the main Maintenance forum.
          - bob
