Official Centurion Press Release:
Merced, CA (December 23, 2016) -Every good story has a backstory. Centurion has just revealed the backstory you need to know if you are ready to get into premium boating. It’s called the Fi23 and it comes with Centurion-quality wakes, waves, ride and more – at a premium-entry level price.
With its aggressive lines, extra wide bow and taper towards transom, the Fi23 makes a distinctive impression even from the dock. On the water, it’s the kind of ride that will ruin your tolerance for lesser boats. Once you step up, it’s hard to go back.
Call It Exotic Sports Car Meets Luxury Sedan.
Forget limitations. The Centurion Fi23 will expand your horizons like your very first boat. The new Opti-V modified deep-v hull design will change your view of the world. Mixing the maximum surf wave displacement and ride quality advantages of a deep-v with balance for a symmetrical wakeboard wake, you will discover the convenience of perfection behind this boat. Its superior handling and fuel economy tell a story of thoughtful design and customer-centric thinking.
The new Split HD Touch Vision dash enables you to control as much as 4,850 pounds of ballast, along with the two-second transfer of QuickSurf Pro and fast, flat take-offs of QuickLaunch. With available RAMFILL, the Fi23 can fill in as little as 45-seconds to create pro-level waves and wakes.
Because Centurion designed the Fi23 to offer an entry-premium price boat, some of the technology and luxuries that reside in the “World’s Best” Ri Series have been taken out of the Fi or made optional. These changes can’t suppress the luxurious interior and exuberant ride you will experience, however. Visit your local Centurion Boats Dealer to find out if this sleek, new, wide bow surf and wake boat is the Centurion for you. Or design the perfect ride in the 2018 Fi23 right now.
2018 Fi23 Specs:
Length: 23’
Beam: 102”
Draft: 32″
Weight: 5150 lbs
Fuel Capacity: 63 gallons
Seating Capacity: 14
Total Available Ballast: 4850 LBS
PNP Bow Ballast: 250 LBS OPT
Bow Ballast Tank: 450 LBS OPT
PNP Rear Ballast: 1650 LBS OPT (2 x 650lbs + 1 350lbs)
Sub-floor Pumped/ RAMFILL PRO Ballast: 2500 LBS STD
About Centurion Boats: Innovation has always been the hallmark of Centurion boats. Now, thanks to new product, leadership and Correct Craft company culture, innovation is running deeper than ever, into a re-imagination of the Centurion brand. Water sports enthusiasts are embracing Centurion boats for the world’s best waves, wakes and ride, as well as ambitious design and inspired craftsmanship. Time to re-imagine your ride, in a Centurion. http://centurionboats.com
About Correct Craft: Celebrating 92 years of excellence in the marine industry, Correct Craft is a Florida-based company with global operations. The Correct Craft family includes Nautique, Centurion, Supreme, Bass Cat, Yar-Craft, SeaArk, and Bryant boat companies, Pleasurecraft Engine Group, and Aktion Parks. For more information please visit http://www.correctcraft.com/.
2018 Fi23 Specs:
Length: 23’
Beam: 102”
Draft: 32″
Weight: 5150 lbs
