2017 G23 Bimini Install Instructions
  • JRW160
    • Jun 2011
    • 42
    • Huntsville, AL
    • 2016 G23
    Does anyone have 2017+ G23 factory bimini install instructions. Mine shipped with instructions for the older bimini. Most of it is the same but I’m not sure what to do with the three velcro straps towards the rear of the bimini. If anyone has pictures of theirs installed, that would probably help too.
  • GMLIII
    • May 2013
    • 2795
    Link attached
    Mounting-FactoryBimini.pdf
    • JRW160
      • Jun 2011
      • 42
      • Huntsville, AL
      • 2016 G23
      Link attached
      [ATTACH]n593317[/ATTACH]
      Those are the instructions for the 2016 and older bimini. Everything is mostly the same except for a couple of things. The crossbar mounts to the midbillet section now instead of the t fittings on the downtube. There are no buckles at the rear of the fabric top as referenced in step 5 of the instructions. There are two sets of velcro webbing on each side and then a velcro piece on top kinda looks like it should line up with the billet mounting arms but doesn't really line up that well.
      • GMLIII
        • May 2013
        • 2795
        Maybe so but I have a 2017 G23 with factory bimini that looks idential to these instructions. and I pulled this instructions from this site under the 2017 manual section
        • JRW160
          • Jun 2011
          • 42
          • Huntsville, AL
          • 2016 G23
          The new bimini I received is a little different from the instructions.They changed the bimini slightly from 2016 to 2017+
