So I bought this 2013 G23 last year. The Z5 Bimini always seemed super low to me, ( I know they are typically low, but it feels lower than it should be). Having never been in another with Z5 I just accepted it as that is normal, however after seeing a few other boats I am sure mine is lower in the front. I was also looking at it and noticed that it is off center and the brackets are not it the same location on the tower. I was hoping someone would have the specific installation instructions for a Z5 on a G23 so I could put the brackets back to where they should be. Or just f someone can measure the location of the tower clamps from a reference point on the boat/ tower. Thank you.
Looks like this will have to wait until the winter time. I tried to just do a quick adjustment on it and a few of the bolts are seized in the aluminum clamps. I will have to drill them out and re-tap unfortunately. I had the same issue with the wake board racks, I realized one only had 1 bolt holding it on and then found the other 3 had already been twos off. Had to drill them out and tap new threads.
Mouse Milk Penetrating oil. A drop and let it soak overnight. For all you saltwater people, it is great for releasing stainless fasteners installed into aluminum.
It does look low in the front. I think you just need to just play with the adjustment. The bimini trend is definitely higher with the over-the-tower designs but I run mine low with just enough clearance for my 5-10 head. I am in Florida and find shade to be more desirable overhead clearance.
I think the Z5 is the best bimini ever produced...unless you need to always drop the tower. I run a full cover over the tower and bimini cover and never take it down.Last edited by srock; 08-02-2023, 10:05 AM.
