Ramlin Trailer - R/Replace Carpet & Plywood
  • nch20skier
    • Feb 2004
    • 167
    • North Carolina
    All-
    It is time to remove/replace the carpeted plywood (what a poopy idea anyhow) on the trailer. I have considered using aluminum (chromed) diamond plate and a non skid plastic (http://www.sdplastics.com/starboardas.html) material. Both would work well, the diamond plate probably look better but more maintenance while the non skid would be easily cut, fit, routed etc and provide a clean look.
    Any thoughts or other options that have been installed?
    88 Barefoot Nautique
    05 206 Team
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    The plastic you are looking at would be non skid if your boat was wearing a pair of shoes.
    http://www.bunkaps.com/product.html
    http://www.ultimatebunkboards.com/index.html
    http://shop.easternmarine.com/index....categoryID=221
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • nch20skier
      • Feb 2004
      • 167
      • North Carolina
      Thanks- these look more for the bunk's I am looking for the walk areas along the outer sides
      05 206 Team
      • AuMDLST
        • Apr 2007
        • 870
        My misunderstanding - I see it now.
        The AL diamond plate is something I have seen and it looks good
        Unless you are looking for it to SHINE - you shouldnt have to do much
        as for upkeep,
        • AirTool
          • Sep 2007
          • 4049
          • Katy, Texas
          What is the material from SD plastics? acrylic? ...if so, much cheaper than West Marine.
          McMaster Carr has 4'x8' sheets of polycarbonate (a.k.a. Lexan) for $450 - ouch.
          You could drill and tap the polycarb and cover it with carpet. I like the feel of carpet but could do without the rot.
          How long did yours last?
          • Toster
            • May 2009
            • 39
            • Lincoln, NE
            I cut mine out of 3/4 plywood, and then covered it (both sides) with truck bed liner. I did 3 coats of the bed liner, and it looks great. On the slanted piece that fits inside the wheel well I covered it in carpet, after the truck bed liner. I didn't want black bed liner to rub on my bow if I had bad loading or unloading. The only problem I have ran in to is if I am not careful when filling the gas and some runs over. I wiped the gas off the boards, and had black rags. I don't know if that was because it was still fairly "new" and had not cured all the way or if that will always be the case.
            Make sure you measure, re-measure, and measure it again. There are some tricky pieces (the triangle piece towards the front, it is NOT a right angle triangle). I also took a 1/4 round over router bit and ran around it all on the top side so I didn't have a square (sharp) corner. I used a 2-1/2 in hole saw, and drilled 2 holes, and then conected them with a jig saw for where the guide post come through the board.
            Hope this helps, if you wait for about another 3 months I might be able to get some pictures.
            • MikeC
              • Apr 2007
              • 535
              • Georgia
              I have the chromed diamond plate on my trailer - easy to keep clean, non slip, fairly easy to replace if needed. But I do like the non-skid plastic idea for some other applications (if I had wood on my trailer it would probably be replaced with it). I did a search for the marine plastics like you found at SD Plastics for two reasons - A 54"x96" sheet of non slip polymer weighs nearly 140 pounds and would be extremely expensive to ship; it costs over $400 for a sheet, and they have a minumum order of $500 or they charge a $50 service fee. I found another supplier, this one in PA that sells different size sheets: http://thecuttingboardfactory.com/Me...egory_Code=4MB , plus I found a number of suppliers that will custom cut plastics for you. I don't know if this will help but the non-skid plastic looks like a good idea.
              • CradGen2
                • Aug 2020
                • 1343
                • Horseheads NY
                I'm going to use King starboard for mine this spring. I have a local source to purchase it.
