210 Prop. 1235 or 5 Blade?
  • highrock
    • Sep 2008
    • 206
    • Salisbury, NC
    • 1995 Ski Nautique (2017-Current) 2015 G21 (2016-Current) 2010 230 (2012-2016) 2008 210 (2008-2012)
    For those of you running a 1235 on their boat with the 5.7 engine, what kind of RPM's are you turning? How much ballast?
    Right now I have the 1619 on my 08 210 with the 343. With about 2500-3500 lbs in ballast. Turning 3800-4100 RPM's. I went with this instead of the 1235 after being advised by acme because of clearance issues, now I wish I would of went with the 1235.
    I am looking to upgrade props this year and I am really thinking possibly going with a new 5 Blade. OJ has one now, my friend dropped about 500 RPM's on their VLX. Acme is testing their new 5 blade currently.
    Any opinions are welcome. Are their other good options out there anyone is using?
    Thanks in advance.
    2010 Super Air 230
    2008 Super Air 210
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    That's way more ballast than i run for riding, so FWIW, here is where you can see and compare the specs on ACME props:
    http://www.acmemarine.com/prop-list_ski-boat.php
    Looking at the 1619 you are using compared to the 1235, it looks like yours is even more aggressive on the hole shot, which is why you are seeing high rpm, and i think the cup might also be part of it as well. First # is the catalog, then diameter followed by the pitch, etc...
    1619 13.50 13.750 0.075 cup 4 1 1/8" LH
    1235 14.50 14.250 0.105 cup 4 1 1/8" LH
    From the Nautique parts web site I found the site (below) that mentions the clearance issue and says that the 1579 is recommended for more pulling power.
    1579 13.50 14.250 0.105 cup 4 1 1/8" LH
    http://www.nautiqueparts.com/propell...nautiques.aspx
    • Sac Surfer
      • Jun 2011
      • 282
      • Mayfied NY, Burlington VT
      • 2010 - 210 Team Edition
      I run the 1579 on my 210. I have wondered about the 5 blades (saw a 5 blade thread on Wakeworld), you think you would end up getting more top end as well as having the low end for getting out of the hole saced out?
      • highrock
        • Sep 2008
        • 206
        • Salisbury, NC
        From what I have heard from Bill at Acme, you lose on the hole shot but do gain on the top end. They say with the less RPM's your running at wakeboard speed you lose some of the ability to really load up a boat.
        Everything that Travis Moye said about the 5 blade lead me to believe different, maybe its the different manufacturers? OJ Vs. Acme. I will say Acme seems to be much better at responding to questions as I have yet to hear from OJ.
        2010 Super Air 230
        2008 Super Air 210
        • HS
          • Oct 2007
          • 1333
          • Sammamish, WA
          interesting read
          http://www.wakeworld.com/forum/showthread.php?t=791336
          • Miljack
            • Dec 2004
            • 1616
            • Charlotte, NC
            • '08 230 TE ZR6
            I'm also curious about the new props, but for the 230. I currently have a 1235 and am very pleased with it so far, but have yet to have many people on the boat, and have only used stock ballast so far. I heard from someone who should know, don't want to drop names, but a sponsored rider with a 230 who tried the 5 blade OJ and didn't like it.
            I rode on an Xstar with a little ballast and the 5 blade, seemed to do fine, but nothing to compare it to. Anybody else used one of the newer props, like the 2249 or 2279? These last two are 15" diameter props which will probably on fit on the 230's, I figured larger diameter, more of a good thing?? :-)
            2008 230 TE-ZR6
            • cloead
              • Jul 2008
              • 40
              I have a 1235 on my 04 210.. boat tops out around 35mph @ 5200rpms.. I usually cruise around 4k @ 20-22mph now
              • Sac Surfer
                • Jun 2011
                • 282
                Jeff is running the 1619 and said it was the best prop that he tested. in the "That's What's Up" thread.
                No one seems to be running the 1433 which is on par with the 1235, but a .5" smaller in diamater, which I leads me to believe this would be similar, but without the gel coat burn issues.
                Acme 1433
                Diameter:
                14"
                Pitch: 14.25"
                Cup: .105
                Rotation: Left Hand
                Shaft: 1 1/8"
                • swankster
                  • Aug 2010
                  • 1052
                  • DFW, TX
                  I put the acme 2245 5 blade on my 2010 230 with the 343hp this morning and will let you know.
                  2010 SANTE 230 343 (280hrs)
                  • core-rider
                    • 1346
                    • Huntsville, AL
                    • 2003 Black SANTE
                    You're running the 1235 on an '04? How close is it to the hull? I don't see anyway to possibly make a 14.5" prop fit without it being VERY close or touching the hull unless you have done some modifications. I was looking at the ACME 1846 to replace my 1464...
                    1846 - 14 x 14.25 .150 cup 4 blade
                    1464 - 13.5 x 14.25 .105 cup 4 blade
                    ACME also said I could try the 2406 - 13.5 x 14.5 .105 cup 5 blade, but thought the 4 blader props would perform better. I don't think ACME has seen many positive reviews from the 5 blade offering so far.
                    Jason
                    All black 2003 SANTE
                    -- Southern Fried --
                    • cloead
                      • Jul 2008
                      • 40
                      Just kidding, I bought a 1236. I keep getting those confused.
