Wakeboard Line???
  • ncarilli
    • May 2013
    • 24
    • California, PA
    • 2003 Ski Nautique 206 Limited
    Wakeboard Line???
    Does anyone know if a Spectra Core Line wrapped with Poly E is as good as a 100% Spectra line? They claim that they are both no stretch, I like the Spectra Core wrapped with Poly E because you can get bright colors for a reasonable amount, let me know your thoughts between http://www.amazon.com/AIRHEAD-Bling-.../dp/B007I6QQ8Y or http://www.boardco.com/shopexd.asp?id=20520 Thanks for your help
  • Yiger
    • Feb 2013
    • 84
    • Maryland
    • 2013 Sport 200
    For sailing lines, the cover is just a UV or chaffing shield. There should be no difference in the strength of the line. Of course that assumes the Spectra portion has the same diameter for both lines.
    • s_kelley2000
      • 1575
      • Fort Meadow Recevoir
      • Mass
      I agree that the the stretch level of a rope is all based on the core and not what it is wrapped in. I am pretty sure the Boardco rope is made by Proline specifically for them and it a quality rope. Airhead makes a lot of relatively cheap watersports equipment. I can't speak to that rope combo in particular but a friend of mine has a vinyl coated Airhead line and the vinyl started cracking after about a year. Also the handle was not very soft. Of those two I would go with the Boardco but here are a few more options, specifically that Pro Line set up: http://www.evo.com/outlet-shop/wake/ropes-handles.aspx
      Take another 20% off with the discount code "wake" and you are paying the same as the Boardco handle with more color options.
      Shawn
      2012 Blue Metal Flake SAN 230
      • biggator
        • Sep 2012
        • 208
        • lake lanier
        • G23
        Spend a few extra bucks and get a good coated line.. Here's some on sale
        http://www.the-house.com/buy-cheap-w...d-handles.html
        Handles are cheap and easy to find what you want.
        • Miljack
          • Dec 2004
          • 1616
          • Charlotte, NC
          • '08 230 TE ZR6
          A little OT, but how often are you guys replacing WB lines?
          2008 230 TE-ZR6
          • s_kelley2000
            • 1575
            • Mass
            My observation has been that as long as you keep them out of the sun and out of the prop they last a LONG time. The Straight Line spectra rope I got for HS graduation along with my LF Trip back in 99 still looks good and it was heavily used until about 08. Another straight line rope that had heavy use from 08 to this year still looks brand new. Both of those are now backup ropes since I scored a great deal on a vinyl coated Accurate A-line over the winter and so far that is holding up good as well. Just like wetsuits, neoprene vests and bindings, leaving ropes in the sun for extended periods of time will definitely shorten their lifespan. I have found that white or bright neon colors tend to help less attentive drivers to keep them out of the prop since they stand out better in the water.
            Shawn
            • migs
              • Aug 2008
              • 702
              • San Mateo, CA
              • SAN 210 TE
              My Accurate A-Line is 6 seasons old @ 100-120 hrs per season. I wont be replacing anytime soon.
              Migs
              G21 - En route
              SAN 210 TE (Finally)
              06 Sky Supreme V220(previous)
              05 Sanger V210(previous)
              01 MC X1(previous)
              99 Air Warrior(previous)
              • ers906
                • Feb 2010
                • 921
                • Phoenix AZ
                I have had great luck with the Ronix square line (not sure what the official name is) and handle (North). No tangle/knotting, etc. easy to coil for storage. Not sure of the cost comparison, but I usually will pick up lines, bindings etc as last years models from the stores in the area or online retailers. Just my 0.02$
                Eric, Phoenix AZ
                G23 550 hp (finally here)
                2002 Super Air
                • ncarilli
                  • May 2013
                  • 24
                  • California, PA
                  Thanks for your help everyone. @ s_kelley2000 thanks for the link, I actually bought that proline one from boardco at the beginning of the season and really liked it but one of my friends got it stuck in my prop the other day and now I am in search for a new one and was looking for a bright color cause maybe it will help! I just ordered the yellow one that was a good deal!
                  • 08sante
                    • Apr 2013
                    • 38
                    • Utah
                    • Current- 2008 Super Air Nautique 230 TE
                    Sounds like you already placed your order, I ride for Boardco and can hook anyone up with 10% off, promo code "jasonh" Great choice in handle btw.
