I recently got my cover sports cover and want to give Brent and crew props on a nice design. No poles, it only takes minutes to put on, is trailerable, gets tight as a drum, and most importantly sheds water like a duck. It uses J hooks to pull tight along the rub rail at the sides. At the back it has little buttons you can attach using the rub rail screws. You can use these to pull the rear straps tight. Nothing attaches to the trailer so you can put it on in the water if you want. I know there have been previous threads on this, but wanted to give my 2 cents.
+1, great cover, it fits like a glove and Brent has been really good to work with. I know a few on here have questioned that but I have talked to him 5+ times and emailed with him 10+ times and he has been responsive and great to work with. I highly recommend his cover, I also added hantyte for the back of my cover as I was getting a little bit of pooling on the two sides in the back of the cover. Now after the hardest of rains and storms my cover is always bone dry.
