Sac Advice
  • frymantcu
    • Jun 2005
    • 31
    • DFW
    Sac Advice
    I have a 2000 Pro Air, and I would like to make my wake bigger! It has 2 hard tanks in the rear, though I'm not sure how big. I was looking at putting a 600 lbs sac in the hull and 250 in the rear. Anyone have a better idea? What kind of setups are everyone else using? And I was thinking about getting a surf board, would I need more sacs, or just move them all to one side?
  • alanholt
    • Oct 2004
    • 34
    • Midlands, UK
    we are having the same "discussions" about weight in our '01 Air Nautique! At present we run standard 400lb in rear tanks, boats converted to LPG so 90ltr gas tank on top of the standard hard tanks. petrol tank converted to ballast 250lb, 200lb in centre ski locker, two 45lb blocks of lead used to balance wake, and then either one 370lb fatsac between engine and rear seat or two370lb fatsacs either side of engine. Normally about 1200lbs. I'm constantly coming under pressure to run more weight to increase our wake size after we borrowed an '05 SANTE for an early morning set! Kinda spoilt us! For surfing we run the same weight but the fatsac over the rear seat/ hatch. I'd be interested to hear what weight others run.
    • frymantcu
      • Jun 2005
      • 31
      • DFW
      What exactly are you talking about, because if I'm reading this right, you made your gas tank bigger? That would be awesome, my tank is so small. My buddy has an 04 wakesetter and we can go out all day, but my boat is done after 3 or 4 hours! Can any nautique dealer add this or is this a custom job you did?
      Your setup sounds like what I had in mind. But I would still love to hear what other people's setups are like.
      • alanholt
        • Oct 2004
        • 34
        • Midlands, UK
        no, we're in the uk and talk funny over here! boat is converted to run on LPG do you guys call that Propane? i'm not sure! we have a 90ltr cylindrical pressurised tank in our rear storage. the standard petrol tank was redundant Gas tank? I converted this to fill with water in tandem with the standard hard tanks in the rear.
        • b2
          • Aug 2004
          • 61
          • Fairford, Gloucestershire. UK
          Hey Alan
          Either get Simon to dredge your lake deeper by at least another 20 feet or just call me and buy another boat. ;-)
          • alanholt
            • Oct 2004
            • 34
            • Midlands, UK
            b2,
            you know we need a SANTE! Don't know if we can afford it but let us know when something tasty comes along!
