I just got a 2012 SAN 210 and I’m wondering what ballast to get and what size of prop. Where should I order from? I want to have the best and biggest wake I can possibly have.
For the prop, go with an ACME 1617, which is a high altitude/heavily weighted prop. It is much better than the standard prop if you are running with a lot of extra ballast. You can order from Delta Prop and use discount code DP9PNA. You can also plumb in ballast from the overflow lines on the stock ballast. I use 2 400 pound bags in the rear lockers and a 650 pound integrated bow sac in the front. Wake Makers will know your boat and set up and send you everything you need to do the install on your own. Good Luck
