Floating boat lift
  • Lakejackson
    • May 2012
    • 160
    • Lake
    • 2011 Sport 200
    Floating boat lift
    Anyone have a Rhinohoist or Hydrohoist lift? Looking to install one and quotes for 5k lb lifts are coming in at $9500 installed. It is a bit higher than I expected. Any suggestions/reviews from those that have had one for awhile?
  • Phil8uga
    • Oct 2016
    • 383
    • Georgia
    I look forward to this topic. Considering buying a lift as well.
    Sent from my iPhone
    • Nolealum
      • Nov 2017
      • 23
      • Atlanta
      • 2014 G25
      I was able to by a Hyrohoist lift from a friend that was upgrading for $1800. Has worked great but 4400 pound capacity and I upgraded boats so needed more capacity. Found a dealer in Alabama that had an extra tank and was able to add it myself and was easy.
      Not sure where you are but was quotes $8k for new 7k pound lift so your quote seems a little high. Agree the mechanics and plastic tanks are simple and shouldn't be too expensive.
      If you look at Craig's List you can find them used every once in a while but suggest a professional install.
      Good luck.
      • distinguishedmotorsports
        • Aug 2016
        • 481
        • Austin, TX
        Its about a dollar per pound brand new with about $500 install on the 4.4k and 6.6k, an 8.8k should run about 600-750 to install, as they are typically wider.
        used going rate is about $0.50 a lb
        FWIW, I like the 8,800lb hydrohoist i have under my boat. i can load up all the gear, fuel and people in the boat and never have concerns about the hoist failing. ****, i could probably bring it in full with ballast.
        • Lakejackson
          • May 2012
          • 160
          • Lake
          • 2011 Sport 200
          Thanks. I purchased a Rhinohoist shallow water from my local dealer. I’ll let everyone know how i like it after I get it installed.
