I have Ronix Preston bindings that are the proper size. They are very comfortable when I first put them on, but after riding for a while my feet begin to "burn". When I say burn I mean the kind of muscle burn you get when lifting weights. This also happens when my 14 year old step son wears these bindings. I've never had this happen with any other bindings and am curious if anyone else has experienced this?
Could just be that the bindings are a poor fit for your feet, while they might be comfortable when first putting them on that doesn't necessarily translate to how they'll feel when riding.
Sounds to me like you have what most of us would refer to as snowboarders foot. Does your whole foot hurt or just a specific area?
First thing I'd do is take a look at how your stance is setup on the board, a change in stance could greatly improve your discomfort.
- Apr 2015
- 1295
- Martinez, GA/Lake Greenwood, SC
- 2017 GS20 Previous: 2011 SAN 210, 2007 Malibu Wakesetter 23LSV, 1995 Cobalt 200
They haven’t been molded. I didn’t even know they could be molded. How can I get them molded?
I have the stance the same as on my other board with older Byerly bindings which don’t cause the burn.
trip33 I agree with you. I thought it was because I don’t ride as much. I’m mostly the boat driver since the kids have gotten into it so much. I would have just thought I was out of riding shape until my 14 year old step son said how much the Preston bindings hurt his feet.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
Most shops have a machine , similar to a snowboard boot heater , Sticknem
on the machine ( basically a well regulated hair dryer) for 10-12 minutes , then lace them up snug with pair of thin socks on , socks becaue they will be warm and it also helps your foot slide in better as well. The shop should also have a toe cap option ( that you put on your toes before you put sock on ) gets you touch more room in toe should you need it. The Fit is night and day after the molding proces.Last edited by swatguy; 07-03-2018, 09:53 PM.
- Apr 2015
- 1295
Originally posted by swatguy View PostMost shops have a machine , similar to a snowboard boot heater , Sticknem
The description on The House website doesn’t mention heat moldable.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
The Preston’s have the stage 3 liner. It’s not heat modleable necessary , it’s marketed as a non heat modleable liner because it uses a much harder foam theor their high end bindings . You can still heat them on the machine and it should help a bit. It won’t ruin them , they just won’t mold as good. It’s part of what keeps the cost down . Ronix has had heat modleable specific liners since their inception in 2006 . They brought them to the forefront. The fact that the Preston doesn’t use their higher end softer , heat specific liner is probably the reason for the pressure points. It’s a much stiffer harder liner , again though heating them
wil help a bit. But may not give you as much relief as you need. Worth trying , but that’s not part of the price point for the Preston’s.Last edited by swatguy; 07-12-2018, 02:04 PM.
I'm not familiar with this. What is the rice bag method?
Unfortunately it shows my age. Been in the sport for a long long time. Used to compete ....used to be Centurion boat sales rep. Lots of gear changes and what not. I will say I haven’t kept up on new boats as much as I used too. I used to know every wake characteristic of every boat, all their pros and cons of every model , but around 2013 I stopped keeping tabs. Just got out of my price range . I still drool tho, and hope to own a GS series one dayLast edited by swatguy; 07-12-2018, 02:09 PM.
Originally posted by Tom_H View Post
Check out this link. Essentially toss rice in a clean sock or stocking, heat it up in the microwave, and stuff it in the boot for a while. Then when the boot is sufficiently warm, you can yank out the rice, put your foot in (with a sock and toe-cap if preferred), tighten it up, and hang out for a while. It basically does the same thing a heater or liner over would do, just a bit easier to do at home. I've done this with all my heat moldable downhill ski boots, and it works great. I just don't know a ton about how moldable the prestons are, so it might take a little trial and error with heating times. If you want some extra toe room molded in, wrap your toes with gauze/paper towels/etc. and put a sock on over that before you shove your foot into the warm boot (it's common practice to do a toe cap of some sort). It's worth a try if you don't have any shops with the blower in your area.
