Third times a charm... busted my prop up again hitting my lift bunks and looking for some advice. I have cantilever hydraulic lift with carpeted load guides on the side. The guides are set to the widest spot on the boat(rub rail). When the boat is lowered there’s a little play from left to right, if the boat ends just a little bit past the perfect spot forward there’s enough play for the prop to hit the bunks under the boat. I’m pretty cautious trying to avoid but it’s not always that easy. I’ve been thinking about adding from guides to the from or maybe a bow stop. Bow stop concerns me about scratches. Any thoughts?
