HO trainer ski question
  • Uncle Phil
    • Jan 2019
    • 21
    • TX
    • 2003 Air Nautique 216
    The little black clip on the rope for HO HotShot training skis broke and HO says you have to buy the whole rope ($44) just to get a new clip. Anyone have a cheaper solution to that?
  • shag
    • 2217
    I don't see why you couldn't get something at a big box store that will work. They are probably telling you that due to liability. I can not see there being an issue as its a 'handheld rope system'..
    • SilentSeven
      • Feb 2014
      • 1955
      • Bellevue WA
      • 2004 Nautique 206
      Did you try contacting HO customer service? That's where I would start...
      Sent from my Pixel 3a using Tapatalk
      Bellevue WA
      • Uncle Phil
        • Jan 2019
        • 21
        • TX
        HO said the whole $44 rope package to get the clip. I asked them if there was a workaround and they wouldn't commit to anything
        • Tigerxj
          • Sep 2020
          • 79
          • SC
          Pretty sure I saw those black bars sold individually
          Yep just found it
          https://www.googleadservices.com/pag...BAgBEBA&adurl=
          $8.49
          Also have one for the Connelly trainers we have
          Sent from my iPhone using Tapatalk Pro
          • srock
            • Oct 2008
            • 1077
            I'll give a little tip on using those trainer skis. Place a little weight on the rear of the ski so the rear sinks and the fronts float. Makes them easy to control while sitting in the water and while getting up. I removed fin screw and replaced it with a longer screw though an approximately 1.5# piece of flat lead on the back of each ski. You may also be able to purchase a kit online.
