The foam in my Nautique trailer guides has worn out. Anyone know where to buy replacement foam? Thanks
Foam for trailer guides
'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190Tags: None
Trailer guide foam? Not sure what that is.
Do you mean the slip on pads on the vertical loading guides?
Nautiqueparts.com has them.
Sent from my Pixel 7 using Tapatalk
Bellevue WA
I have the guides already. The foam inside has worn out and I want to replace that. I can only find places to buy the entire thing. The foam should only cost a few dollars not $65.'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
You should be able to find the right interior and exterior dimensions by looking for pipe insulation from places like Grainger’s. It will be way cheaper than paying up for a whole new set!
What is the diameter of that foam, 2 1/2"?
It's pretty hard not to be able to find something on The Amazon. Search Foam Pipe Insulation using the diameter, and then narrow down the wall thickness.
Not sure you are going to save that much over just buying some new custom bling pads.
Like others have said I think it is just pipe insulation. Take a piece to Home Depot and see what fits or take measurements and look online. If yours are too deteriorated to get measurements, I can take some off the new pair of Nautique Parts ones that I just installed at the beginning of this season if you want.Shawn
2012 Blue Metal Flake SAN 230
