i need help to learn a board grab!!!!!!!!!!!!!!!
  • ryanclippers18
    • 18
    • ontario
    • nautique 211
    i just learned how to go WTW and was just learning how to do a board grab any suggestions would be helpful thanks
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Learnwake.com. Also, do you have a trampoline? They make a little board you can wear on a trampoline. It can help with some of the grabs.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • ryanclippers18
      • 18
      • ontario
      • nautique 211
      Ya I do have a trampoline. Where can I get the board and how much do they cost?
      • Chexi
        • Apr 2025
        • 2119
        • Austin
        • 2000 SAN
        $100. Jumpsport.com or amazon. Learnwake.com is where I would start though.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • ryanclippers18
          • 18
          • ontario
          • nautique 211
          ok i already have learn wake and it helped me do the wtw
          • ryanclippers18
            • 18
            • ontario
            • nautique 211
            how big is the board i might have a little board that might work?
            • Chexi
              • Apr 2025
              • 2119
              • Austin
              • 2000 SAN
              34"x12"x2"
              http://www.jumpsport.com/pr-bounceboard.htm
              I would not use an old board. It will tear up your trampoline. The bounceboard is designed not to tear up your trampoline.
              Now
              2000 SAN
              Previously
              1999 Air Nautique
              1996 Tige Pre-2000
              • ryanclippers18
                • 18
                • ontario
                • nautique 211
                i checked it out they r expensive so i found a board in my grage that work it is not a real wakeboard it is like the bounce board
                • wake4life6
                  • Mar 2009
                  • 218
                  • Olympia, Washington
                  If you want a cheaper option use an old skate deck or buy a blank http://www.amazon.com/Blank-Decks-Wa.../dp/B004KAS2EW . Then add straps or screw, bolt, glue or tape some old shoes to it.
                  2006 210 SAN! TE
