Wandering mind - water cannon
  • TurboFan
    • May 2011
    • 47
    • Salt Lake City
    If you want to piss them off, go with a shower. If you want to make them think twice, you're going to need some serious water. A fire hose starts at about 125 GPM. A pump like this
    http://www.amazon.com/IPT-Gorman-Rup.../dp/B000N4T7VG
    might get you started, but I'm not sure where you're going to get the power for any kind of pump to put out meaningful water. 2HP is quite a bit of power for your alternator!
    I think you'll probably have to go gas powered for your little project. Check this guy out!
    http://forums.sscentral.org/t4126/
    • Texan1554
      • Apr 2011
      • 220
      • Dallas
      • 2002 SANTE
      Tower mounted water balloon sling shots work very well actually. Pretty common to see em out on the 4th.
      2002 SANTE
      • SkiTower
        • 2172
        • Clayton, NC
        not exactly a 'cannon' but it'd be funny to pull one out and chase a jetskier!
        http://www.youtube.com/watch?v=im1iNq02Kz0
        2007 SV211 SE
        Tow Vehicle 2019 Tundra
        Dealer: www.Whitelake.com
        • Texan1554
          • Apr 2011
          • 220
          • Dallas
          • 2002 SANTE
          Man, I want one.
          2002 SANTE
          • SkiTower
            • 2172
            • Clayton, NC
            Only $146K
            2007 SV211 SE
            • Chris4x4Gill2
              • Jul 2008
              • 406
              • Smith Lake, AL
              • '89 Ski Nautique 2001
              #21
              I think the easiest way to accomplish a water cannon, would be a seperate system fro mthe ballast. You could T into the ballast supply line so you dont add and additional thru hull, but then I think you would need a different pump w/ greater pressure than a ballast pump is capable of.
              You could get away without using an additional tank if you start with a larger line going into the new pump and reduce it coming out.
              Should be pretty simple to setup, you would just have to find the right pump.
              • HS
                • Oct 2007
                • 1333
                • Sammamish, WA
                • 2010 SANTE 210 (Sold)
                #22
                what would a Tsunami pump do if it had a nozzle?
