PWT boat question
  • natepribyl
    • Apr 2012
    • 27
    • Minnesota
    • 2017 G23 550
    PWT boat question
    If Supra is having the SL as there new flagship wake boat why is the SA puling the contests for 2018?
    They could have made the change from 2017 to 18 when the SL came out in late 17?
    Anyone know if the wake on the SA is better?
  • Shockthis
    • Mar 2013
    • 302
    • Christina Lake BC
    • 2021 centurion ri245
    The Sl has a little more kick at the top compared to the SA , the SL is very similar to the G
    The SL had a way better surf wake but the still used the SA to pull wakesurf comps too
    • Infinity
      • Sep 2017
      • 730
      • Lake Norman - Denver, NC
      • 2014 SV244 w/ ZR409
      I have surfed behind both the SA and the SL. Both have a great wave....the SL can do it with less ballast. The SA I have ridden in multiple times runs 1000lbs of lead on top of all the ballast....SL was stock ballast only without PnP + 600lbs of lead and I prefered the SL wave. Shape and form was great on them both, but I felt the SL was a good bit longer
      • Shockthis
        • Mar 2013
        • 302
        • Christina Lake BC
        Go talk to Andrew at Nissiwa Marine he could probably give you the scoop on the wakeboard wake of the SL, I found that it has a good transition, a nice firm lip and a little kick at the top of the wake.
