I was able to complete the one panel I started yesterday.  I think it turned out pretty good.  Let me know what yall think.
Also, as I am finishing the panels, I am tightening the bolts that hold the pad to the boat. You have to hold the bolt and then tighten the square nut. For those that have loose pads, it's probably because this square nut has come loose.
I started on the long one that has two speakers in it. I got the baffle made for the one just like the completed piece. All I have to do for this piece is to make the thicker one. I think that I can make it thick enough by adding only one other layer of wood. Then it's off to the bow, and I'm done. Good thing as I am getting tired of cutting holes. I think I need to make me a cnc router. I have attached a pic of the piece of mdf that I started with last summer. It used to be a full 8ft sheet. If you take every hole in there and multiply by two you end up with the total number of times I had to cut a hole. There's gotta be a better way.
Enjoy!
Enjoy!
