bow speaker question
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    I have a 2003 SAN TE that I bought from an individual. the guy before me put Memphis speakers throughout the boat. Each speaker has it's own fuses box about 5 inches from the speaker itself. 3 of the fuses are blown. 2 are an easy fix. Both bow speakers have a blown fuse. I can easily change the right one through the storage compartment. the left one is where my question comes in. I took the panel off under the steering wheel and that did me no good. If you take the front bow cushion off you can see it but not gonna be easy. the other bow cushion has the cooler in it. If the cooler was not there this would be easy. I can't even see how to remove the cooler. Any suggestions would be appreciated.
    Justin
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: bow speaker question
    Fuses are used as a protection device - I would be looking for the cause of the fuses blowing or else you will be replacing these many more times in the future - most likely right after you install them
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • jward
      • Feb 2008
      • 620
      • 03 SANTE 04 SANTE
      found out it was not a fuse. I took it out and it is a crossover. there is a light in it and that is what is blown. The speakers have got to be blown
      • AuMDLST
        • Apr 2007
        • 870
        are they connected to an amp? - have you tried to connect the non working speakers to a known set of working terminals - the light would be an indicator of signal/wattage - without the light working I would look at the source - that being either an amp or a head unit in some cases
