Question For Skinautique Or Anyone Else That Can Help
  • FatBoy
    • Mar 2004
    • 756
    • Eastern North Carolina
    I am putting a new amp in my SV-211 and was wondering if it would be safe to mount it in the same manner as the small one mounted at the factory. I don't want to run a screw thru the hull. This area looks like an inner wall with foam in between, and if so I can screw the amp down like the other one is but I want to be sure. Any help would be welcome.
    Life is Short, Live it!
    http://www.teamcarolina.us/index.htm
  • MinnesotaNautique
    • Jan 2004
    • 207
    FatBoy,
    Your better off gluing a piece of wood to the carpet/or fiberglass and then mounting the amp to the wood...I should know, as we drilled through the hull like a couple of Jack-A*S's about two weeks ago. Don't be that guy...you'd be surprised how short the distance is between the inner wall and the outer portion of the hull.
    • skinautique
      • 1749
      • Colorado
      You can do it but be careful of the screw size you use. I am not sure of the screw size off the top of my head. I have seen plenty of amps mounted there though.
      • FatBoy
        • Mar 2004
        • 756
        Thanks for the advise. Just to be on the safe side I cut a pc. of 1/2 incm highfax and glued it to the carpet. I then fastened the amp to that.
