Adding a pair of tower speakers
  • Batman
    • Jan 2005
    • 186
    • Kingsport, TN
    I have a pair of Kicker tower speakers and want to add another pair like them on my tower. Can I run wire from one set to the other, like pos=pos and neg=neg. I really hope this is the solution. I have a Kicker 350.2 running the tower speakers and sub. Interior runs off head unit. Thanks
    If you don\'t do it today, you will be one day older when you do!!
  • Latonkaboarder
    • Jul 2007
    • 372
    • Mercer, Pennsylvania
    • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
    RE: Adding a pair of tower speakers
    As long as your amp can handle the load it won't be a problem. Check out this link it is very helpful. Remember the lower the impedance the more power, which in turn creates more heat on the amp. http://www.bcae1.com/spkrmlti.htm
    Current: 08 Super Air 210 Team
    Previous: 07 Super Air 210 Team
    Previous: 02 MC Pro Star 197
    • AuMDLST
      • Apr 2007
      • 870
      • Orlando, FL (Butler Chain)
      are you running both tower speakers on one channel and the sub on the second channel? - the kicker 350.2 is speced out at 175 watts (2 ohms) X2 - if the current kicker tower speakers are 4 ohms each and wired in parallel you would have a 2 ohm load on one channel - and whatever load the sub represents on the other - you will be underpowered by quite a bit if you add two more speakers to the same channel besides reducing the resistance of the load to the point of potential failure
      2006 SANTE 210 (Pending Sale)
      2005 206 TE (Previous)
