Static sound @ Higher volumes- Advice??
  • yeaitsmemarc
    • Aug 2007
    • 9
    • Lake Lillinonah, CT
    I have a Nautique 236 which came with tower speakers, a sub and 2 amps.. The system sounds great at low volumes but when I set it above ~20 the lower speakers sound terrible (muffled or static like) (Similar to blasting music from a $20 boom-box). I restored all factory default wire settings and it has not improved anything. Any advice would be very much appreciated. Thanks!
    -Marc
  • TravisFling
    • Mar 2008
    • 889
    • London, Ohio
    • 1989 Ski Nautique 2001
    RE: Static sound @ Higher volumes- Advice??
    Have you checked the levels on the amps? it sounds like something is clipping or maxed out...
    Travis Fling
    Choctaw Lake
    • 78LS2
      • Oct 2006
      • 183
      gain on the amp is probably too high for those speakers. or, the crossovers are set wrong (not sure which amps you have, so they may or may not have X-overs).
      \'03 196 LTD
