Wiring configuration for 6 speakers
  • TravisFling
    • Mar 2008
    • 889
    • London, Ohio
    • 1989 Ski Nautique 2001
    I have an amp that can handle a 2 ohm load and 6 4 ohm speakers. How do I wire them (some combination of series and parallel) to get a 2 ohm load?
    Travis Fling
    Choctaw Lake
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    RE: Wiring configuration for 6 speakers
    IIRC in series R total = R1 + R2 + R3 + .... + Rn
    in parallel 1/Rtotal = (1/R1) + (1/R2) + (1/R3) + ... + (1/Rn)
    Play around with it. I don't think it will work. How many channels do you have?
    AirTool
    • TravisFling
      • Mar 2008
      • 889
      • London, Ohio
      2 channels... I guess I'll have to run some off the headunit, or something. that's a real bummer.
      Can I run 1 channel running four speakers in series and then just connect the other two in parralel to the amp? Or can you not mix ohm loads accross channels?
      Travis Fling
      Choctaw Lake
      • RJ
        • Aug 2007
        • 38
        • SE-WI
        Ive got 6 speakers on 2 channels. This is not what most would recomend but it works for me. I'm running a Kicker 650.4, I connected 3 4ohm Kicker impulse speakers each on channels 1 and 2. I wired 2 in series and the third in parallel. 4ohm + 4ohms - 4ohms? Im guessing it would be in 4 to 6 ohm range. Im currently only running this single 4 channel amp pushing these 6 speakers on the 2 channels and a 12" sub bridged on the other two. It works great for now.
        \'02 BLK SANTE
        • TravisFling
          • Mar 2008
          • 889
          • London, Ohio
          A quick update for those who are interested... I have gotten some advice that you can hook up all three in parallel by adding a 250 microfarad capacitor to the positive lead of one of the speakers, which not only acts as a passive equalizer, cutting the bass to your midrange (!!!) but ALSO increases the resistance making the total ohm load around 2-4, or somewhere in the 3 range!!! YEE-HAW!! I will give it a try...
          RJ - How do you like that Kicker 650.4? That's the exact amp I'm getting, and boy am I excited!!
          Travis Fling
          Choctaw Lake
          • gride300
            • Apr 2008
            • 1356
            • mobile, al
            from the factory the front polk's are run off the h/u. the rear are run at 2ohms on one channel and then the sub is bridged i believe. i think it is absolutely garbage to so poorly amplify such a nice speakers which is why i run 4 amps, dedicated jl marine sub amp, clarion 2 and 4 ch marine for all 6 in boat speakers, and a kicker 4 ch for my tower. also, running so many speakers on one channel cuts their power in half almost for each additional speaker
            • RJ
              • Aug 2007
              • 38
              • SE-WI
              Hey Travis I am very happy with the 650.4 it cranks!
              I installed the amp earlier this spring, Here is a pic. I just finished putting in the LEDs. I plan on running NVS tower speakers but Im not there yet....$$$$ Yellow_Flash_Colorz:, but when I do I will go with a second KICKER amp.
              \'02 BLK SANTE
              • TravisFling
                • Mar 2008
                • 889
                • London, Ohio
                Hey Gride300... The power being cut actually HELPS me out a great deal. My Polk's are rated at 60 watts RMS, which is pretty typical for a 6.5/6.75 so 170w / 3 is perfect for my application, but I do agree that stock the speakers are way underpowered. I think it's a liability thing, or that old people don't like loud music. Either way... I'm building all this from scratch being that I have a 1989 2001 boat, so it leaves it pretty open. I wanted to get back to one amp for the time being, that could power everything that I have. I may put one of my existing amps back in once I get it all the tower speakers up, but I really wanted to get back to one amp.... Anyway, I hope that makes sense.
                Travis Fling
                Choctaw Lake
