So started wiring everything up today, got the amp rack made as well as the sub box. Bolted the amps in, and got the tower speakers up. Put the Wetsounds WS-420 EQ under the dash just to get everything hooked up and ran into some issues. I'm almost certain its a faulty unit. Everything on it works except the tower input. Hooked everything up to the EQ, all the other speakers worked (bow, rear, sub, etc.). Heard a weird sound almost like a vacuum coming from the tower speakers at first...then nothing. Decided to trouble shoot some and actually hooked up everything to the Clarion headunit and everything worked. I wanted to make sure it wasn't the tower speakers, and I wanted to make sure it wasn't the Kicker ZX850.4 amplifier giving me the issues. Then decided to do some switching out of cables and still the same issue...no noise at all from the tower speakers. Even ran the tower speakers off of the different selections on the EQ just to see if all the other inputs/outputs worked and it was fine.
One thing I read on a few other websites, Malibucrew.com and wakeworld.com, was the WS-420 actually has given some more issues than none. Mine seemed to be the same issue, but I tried some of the remedies--turn all the gains down, set the EQ gains to equal, etc. Still no luck. I'm going to call Wakeside.com where I ordered the unit from and see if they can get me an exchange. Pretty disappointed because I was really hoping I would have everything up and running by today. Oh well, looks like it'll have to wait!
Any suggestions? Tim, would be great if you could chime in and give me your input. Thanks again!
