I was trying to track down the amp shutting off problem I posted about earlier and stripped the terminal the ground attaches to. Anyone know how to fix this, other than running out and buying a new amp. Help! No tunes and weekend is near!
Tags: None
RE: Help, Stripped terminal on my amp!!
Thanks, I'm going to give that a try tomorrow. Talked to a buddy that recommended the same thing.
that's the fix. If you get to the point where you can't accept a bigger screw due to the head of the screw being too large move to a set screw with an internal hex, so there's no head, like a kicker amp would have, as opposed to a phillips head that flanges out. I'm not sure if that makes sense, but if you get to that point and don't get it I can post a pic.Travis Fling
Choctaw Lake
Success!! Drilling it out and tapping worked perfect. Thanks for the advice.
that's always good to hear!!! How did the weekend go? I spent mine helping my FIL get the pooh out of his motorhome with a gator and a pull behind pooh dumper, since I'm STILL waiting on my new tower foot piece from Boss Wake, even though they sent it 8 days ago.. scheduled to arrive Thursday...Travis Fling
Choctaw Lake
