Hi guys,
I asked before, but I didn't get a satisfied anwser (most likely the anwser were correct, but I really didn't get it :o ).
Our original CC tower speakers set are connected via a 2 wire conductor harness to a Clarion APX280 2 channel amp.
Because the four speakers are setup in parallel in setups of 2 the amplifier sees on each channel 2ohm and therefore.
So originally you'll get around 18V to the speakers (P= (U^2) /2 -> U= sqrt(P*R)=160*2=18V). This is quite easy to follow for me.
But now I want to put a Clarion 480 four channel amp to these four speakers with a 2 wire conductor harness... I heard from mikeski that you will need to bridge the 4 channels to 2 channels and to serilize the speakers. So the speakers will get to 8ohm. The bridged channel will be double the Voltage to around 36V. But how I now calculate is that the power will still be 160W to the speakers... I hope that something I do is wrong, but I really could use somebody's help with this. MikeSki?!
Thanks, Tom
Thanks, Tom
