tower wiring
  • fitzee
    • Feb 2008
    • 127
    tower wiring
    what is the best tower harness to run 4 tower speaker (polk) or can you just run speaker wire
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: tower wiring
    Are you talking about 4 individual speakers or the double cans? Either way you just need some decent 14ga (12ga at the most) speaker wire. I would look for some twisted pair with a jacket.
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • AuMDLST
      • Apr 2007
      • 870
      RE: tower wiring
      [http://www.cablestogo.com/product_li...mp;dept_name=]
      Not necessary to have an in wall rating but something like this
      • AuMDLST
        • Apr 2007
        • 870
        RE: tower wiring
        [url]http://www.cablestogo.com/product_list.asp?ListAbsolutePage=2&list_Pagin gMove=Previous&row=1&cat_id=315&dept_i d=&dept_name=
        • AuMDLST
          • Apr 2007
          • 870
          RE: tower wiring
          trying to figure how to make the link work?
          • Chris4x4Gill2
            • Jul 2008
            • 406
            • Smith Lake, AL
            • '89 Ski Nautique 2001
            RE: tower wiring
            Here ya go
            http://www.cablestogo.com/product_li...amp;dept_name=
            AuMDLST: you have to close the link with the URL button as well. it should be
            https://<a href="https://www.YourLin...nkHere.com</a>
            nevermind, looks like the forum auto links them as well
            • fitzee
              • Feb 2008
              • 127
              i'm running the polk tower speakers 4 of them and they all have connectors so do i run 4 speaker wire or 2
              and i want to add an amp or two so if i added 2 more claroin 480s that would give me 12 channels that would let me amp all mids /sub/tower and would i have to run another battery or is 2 enough i also have a line driver if that helps any
              or if anybody can suggest a better setup to run this system that would great
              HOW TO SET THIS SYTEM UP OR PICTURES OF OTHERS SYSTEMS INSTALLED
              • AuMDLST
                • Apr 2007
                • 870
                you will need one pair of wire per speaker (one black and one red wire (1 pair)). You currently have what amps? One clarion 480 would be sufficient for the tower speaker (one channel per speaker). The current (if you have) 480 is good for the current setup (4 cabin speakers?). Do you have a clarion 280? If so use that for the bow speakers. Use a dedicated amp for the sub ( is it factory sub?) Do you use the boat for boarding or just hanging out? I ask because you do not need to worry about the charging system as well as the batteries if you "use" the boat. I have an 06 210 as well with clarion 480, 280 - kicker 750.1 and 850.4 - all on factory interstate batteries and will run the stereo for several hours as loud as you want without hesitation at startup.
                • kevfran99
                  • Sep 2008
                  • 335
                  • ATL
                  • 08 210 SAN Team
                  just do what I did. Buy a jl 6 channel marine amp and run the six interior speakers off of it, one per channel. Run the four tower speakers off the clarion 480, one per channel, and then run your sub from the 2 channel amp bridged to one channel! Sounds great! no need for another battery. Leave the two factory wired just as they are and then power the 6 channel right from the port side battery!
                  '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
                  Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
                  -GO DAWGS!-
                  • fitzee
                    • Feb 2008
                    • 127
                    thanks for the help hey kevfran99 can you post some picks of the install and wiring thanks if possible
                      • 2908
                      Stuff I have been using for 5 years, can't find anything better:
                      http://www.audiopile.net/products/Sp...cutsheet_2.asp
                      • Miljack
                        • Dec 2004
                        • 1616
                        • Charlotte, NC
                        • '08 230 TE ZR6
                        Mike,
                        How do you run the cable inside the tower? Are you able to purchase without the connectors soldered (sp?). Or do you sweat them off when you get them? Roughly what's the OD of the cable?
                        thanks
                        2008 230 TE-ZR6
                        • AuMDLST
                          • Apr 2007
                          • 870
                          Miljack - the nutrik connectors use screw set and are not soldered. Do you have holes in the tower? If not you will have to drill them. Afterwards use a vacuum to suck a pull string in and you are good to attach the wire and pull through.
                            • 2908
                            Here is a tower wiring tutorial I did on wakeworld:
                            http://www.wakeworld.com/MB/Discus/m...21/221331.html
