tower wiring
  • fitzee
    • Feb 2008
    • 127
    tower wiring
    wheres the best place to bring the 4 tower speakers wires out any pics would be great going to start my winter stereo upgrade running wires adding 2 new amps and figuring this system out
    so this is my plan if anybody has any ideas please let me know
    2channel clarion amp for sub (not bought yet)
    4 channel clarion amp for 6 interior speakers (have 1)
    4 channel clarion for 4 tower speakes (not bought yet)
    any brands or amps suggestions can i run the second amp back to the stock location if the boat came with 2 amps fuse in rear hatch
    any pics to help me out would be great
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • Quinner
    • 2246
    • Correct Crafts
    RE: tower wiring
    Fitzee,
    Do some searching on this topic, there are many posts out there with pic's and descriptions that should help you through the entire process.
    Installed mine a couple years ago, spent more time planning and chasing parts then doing the actual install.
    Quick list of items:
    Place to mount amps
    at tower: Speaker Wire, Wiremold, Grommets, Connecters
    power to amps: Wire, wiremold, fuse(s), connectors
    The list could go on depending on how elaborate or how much ca$h you want to spend.
    Good Luck
    • bkhallpass
      • 1407
      • Discovery Bay, CA
      RE: tower wiring
      I like the wiring installation that Mikeski did on his boat. Perhaps he will chime in.
      BKH
      2001 Super Air
      • AuMDLST
        • Apr 2007
        • 870
        • Orlando, FL (Butler Chain)
        RE: tower wiring
        If the tower was not prewired you need to crawl under the lookout seat and dash area and drill out the fiberglass to access the internal tower leg. The tower mounting plate should already have a hole in it. You need to drill one hole above and below the tower joint for the tower speaker wire. 12ga wire is fine for the tower speakers. Which tower speakers? Four individuals or combo's like NVS or Wetsounds? Thereby requiring either two or four holes. What do you want to accomplish? The loudest boomiest boat out there or just a casual sit on the beach and enjoy without waking the neighbors?
        2006 SANTE 210 (Pending Sale)
        2005 206 TE (Previous)
        • fitzee
          • Feb 2008
          • 127
          wheres the best place to bring the wire out at the top of the tower what do they do from factory
          • Quinner
            • 2246
            • Correct Crafts
            Referring to AuMD's post, I ran my speaker wire up the port/passenger side, (the tower foot and hull were pre-drilled at the factory on my 206), then out lower - in upper. Up top I came out the back of the front bar with mine, some have fished the wire to the back bar which is quite a bit more involved.
            • fitzee
              • Feb 2008
              • 127
              anybody have pics og pre wired boat
                • 2908
                tutorial...
                http://www.wakeworld.com/MB/Discus/m...21/221331.html
