Does anyone know how the 2009 models come wired from the factory? I ordered my 210 with the tower speaker prep kit that has the 500.4 Polk amp and factory tower wiring. I am assuming there will be four cables wired from the amp to the tower since it is a 4 channel amp. Can anyone confirm this?
RE: Tower wiring on 2009 models
Ask your dealer to call and make sure. My 08 model came prepped for 2 speakers instead of 4, but I didn't order the amp either.
You don't need the tower to be wired for four speakers to run four speakers. You just need to get the combination of series or parallel speaker wiring to match the combination of stereo or mono amp wiring. The stock wires should work just fine.
If for some reason your boat comes with only 2 wires from the factory, just tape 2 sets of speaker wire (at different points) to the end of your current line and pull them down through the tower. This will fish two sets of wire through all the holes of your tower. Its super easy.
