Wire 2 subs on 1 channel in parallel?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Okay, my new to me boat came with a monoblock Alpine amp with only 1 speaker pair out. It also came with 2 Kicker 12" subs (only 1 of which was hooked up). Is there a way to wire the subs together, not do damage to the system, and have them both work properly? Is it as easy as wiring the subs in parallel? Would I gain any benefit from the second sub? They are right next to each other.
    Forgive me, I am a noob at car/marine audio.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
  • brodie
    • 125
    • MN
    That amp will run @ 2 ohms, so go ahead and wire them in parallel. You will gain some extra oomf!
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      That is kind of what I thought. That's great news. Cheap and easy, just like I like my... .
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • TravisFling
        • Mar 2008
        • 889
        • London, Ohio
        • 1989 Ski Nautique 2001
        Hey now!!! Yep you can just run pos 1 and pos 2 to channel 1 pos and neg 1 and neg 2 to channel 1 neg and should be just fine. Should give you a little more kick, eh?
        Travis Fling
        Choctaw Lake
        • Chexi
          • Apr 2025
          • 2119
          • Austin
          • 2000 SAN
          Thank you gentlemen. I'll give it a try and see. It might just be too much kick!
          Now
          2000 SAN
          Previously
          1999 Air Nautique
          1996 Tige Pre-2000
            • 2908
            Watch the amp, if it is running too hot it's possible you are below 1 ohm with the subs. If you have a multimeter you might want to measure the resistance of the subs. It will not be exactly the same as the impedence but it should be close. If you get less than 1 ohm when they are wired together you might have issues. For example if each has dual 2 ohm voice coils already wired in parallel then you will be down to 1/2 ohm load on the amp so you would need to wire them in series. If they have single 2 ohm or dual 4 ohm voice coils wire everything in parallel and you should be good to go.
            When in doubt www.bcae1.com
