Wire
  • fitzee
    • Feb 2008
    • 127
    Wire
    just going out this weekend to buy my amp wire for my second amp should i ground it off the battery where the first amp is grounded or run the wire to the second battery
    and ground it there
    i'm running 8 gauge wire same as factory
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • Chexi
    • Feb 2025
    • 2119
    • Austin
    • 2000 SAN
    RE: Wire
    Best check those loads. I think that if you are adding a second amp, you may be increasing the current that will flow through those wires. 8 gauge may not be sufficient for a your upgraded system.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • fitzee
      • Feb 2008
      • 127
      you have to run a separate (8 gauge power and ground) to a fuse for each amp just wondering if i can run the ground to the same battery
      • Chexi
        • Feb 2025
        • 2119
        • Austin
        • 2000 SAN
        I misunderstood. I thought you were running 8AWG from the battery to the distribution block.
        Now
        2000 SAN
        Previously
        1999 Air Nautique
        1996 Tige Pre-2000
        • jaybird
          • Oct 2008
          • 516
          • North Alabama Lake Weiss
          Fitzee,
          careful, Your wire size depends on your amps and length of wire run.
          this is a good guide: http://www.the12volt.com/info/recwirsz.asp
          2012 Team Ski Nautique ZR409
          2011 Sport Nautique 200
          2008 SANT 230
          2003 Air Nautique 226
          1988 Martinique
          1979 Nautique
          1978 Tique
          1976 Tique (First New Boat)
          • fitzee
            • Feb 2008
            • 127
            i'm just running what factory ran for the 4 channel clarion thats in the boat now only difference is i'm going to put in the new clarion 4 channel apx490m so i thought i would do it the same then for breaker i just going to run it into the breaker box where the other breaker are by the battery shut where it has a breaker for a second amp is this a easy task (boat only came with one amp adding another one)
            • Chexi
              • Feb 2025
              • 2119
              • Austin
              • 2000 SAN
              Punctuation helps.
              Now
              2000 SAN
              Previously
              1999 Air Nautique
              1996 Tige Pre-2000
              • AuMDLST
                • Apr 2007
                • 870
                • Orlando, FL (Butler Chain)
                Are you sure you have an amp wired through a breaker? What size (current rating) is the breaker? I believe you should have an inline fuse on the 8ga for the amp.
                2006 SANTE 210 (Pending Sale)
                2005 206 TE (Previous)
                • fitzee
                  • Feb 2008
                  • 127
                  no i'm not sure just by looking at it it looks like and it says- amp 1- amp2-stereo-auto bilige-power-and it has the big red battery shut off switch 1-2-all and its in the back storage compartment and seems everything runs into it
                  it has the red push button style breakers and for the amp that there now it has a 50 and for spot where it says amp 2 it has a 30 which i was going to change out and put a 50 in
                  hopefully someone knows what i'm talking about
