mounting amp
  • fitzee
    • Feb 2008
    • 127
    mounting amp
    does anybody know what the thinkness of the material that cc puts in to mount amps to under passenger seat compartment don't really want to tear carpet down to measure and don't want to put screw through hull
    whats max length screw you can use without going out the side of the boat
    thanks
    made custom amp rack to hold 2 amps out of 5/8 material and need to fasten
    2006 Super Air 210 Team Edition(SOLD)
    1995 MB Sports boss 200 (SOLD)
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    RE: mounting amp
    I learned a long time ago to not test that one. Personally I would use a couple big chunks of the hook side of velcro. Or , depending upon what your 5/8 material is, remove the carpet nice and clean smaller than your panel, and adhere it with epoxy or something of the sort. Whatever is appropriate for your material.
    the WakeSlayer
    1968 Correct Craft Mustang
    • Chexi
      • Apr 2025
      • 2119
      • Austin
      • 2000 SAN
      RE: mounting amp
      I was just wondering the same thing (i.e., how to mount a buffer board to hold my amps). I would not have thought of velcro. Thanks Wakeslayer!
      Now
      2000 SAN
      Previously
      1999 Air Nautique
      1996 Tige Pre-2000
      • WakeSlayer
        • Sep 2005
        • 2069
        • Silver Creek, MN
        • 1968 Mustang
        RE: mounting amp
        May not be the best way, but you won't have a hole in your boat, nor mess with your carpeting.
        I accidentally drilled a 3/32 hole through my SN in 1996. A cleverly placed decal fixed the problem, but I still won't even drill intentional ones because the experience freaked me out. I make my brother or a buddy do it. Both think it is quite funny to this day. I, however, do not...
        the WakeSlayer
        • Quinner
          • 2246
          • Correct Crafts
          RE: mounting amp
          Fitzee,
          You may want to check with your dealer or Call CC directly. I removed one of the screws on the factory installed amp and used it to match up for the additional screws required for the second amp.
