Speaker - Ohm - Amp Question
  • hornsfan
    • Feb 2009
    • 60
    All right first off I inherited this amp from the previous boat owner.
    I have an Alpine MRP-T220
    Alpine Amp Specs:
    50 watts RMS x 2 at 4 ohms
    70 watts RMS x 2 at 2 ohms
    140 watts RMS x 1 bridged output at 4 ohms
    stereo or bridged mono output
    4-ohm stable in bridged mode
    MOSFET power supply
    I am looking at buying (4) Polk db651
    Overall Frequency Response 35Hz-22kHz
    Nominal Impedance 4 ohms
    Power Handling (continuous) 60 w
    Power Handling (peak) 180 w
    Efficiency 92 dB
    My question is this: Can I run all 4 speakers on this 2-channel amp in parallel?
    So that my wiring would look like this?
  • brodie
    • 125
    • MN
    Yes, you would wire them exactly like the diagram shows. Each speaker will get ~35 watts. I have the same speakers, with about the same power and they sound pretty good. If you add a sub, they will sound even better.
