Anyone know what size diameter hole I need to cut outta my box i'm making to put the Polk Momo 10" sub in from my 06 Sante? My boat's still tucked away for winter.
Tags: None
RE: POLK MOMO 10" SUB HOLE?
Size 10 -inch
Impedance 4 ohms
Cone Material Polypropylene
Surround Material Rubber
Sealed Box Volume (cubic feet) 0.66
Ported Box Volume (cubic feet) N/A
Port diameter (inches) N/A
Port length (inches) N/A
Free-Air No
Dual Voice Coil No
Sensitivity 86 dB at 1 volt
Frequency Response 24 - 200 Hz
RMS Power Range (Watts) 50-300
Peak Power Handling (Watts) 600
Top Mount Depth (inches) 5 3/4
Bottom Mount Depth (inches) 6 3/16
Cutout Diameter or Length (inches) 9 3/16
Vas (liters) 30.67
Fs (Hz) 35.2
Qts 0.48
Xmax (millimeters) 9
Parts Warranty 3 Years
Labor Warranty 3 Years
Above are the specs for a 2104 and it is a 9 and 3/16" diameter cutout2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
You can view it at crutchfield
http://www.crutchfield.com/S-ZpFFKV1...MO-MM2104.html
If in fact this is your sub
Either way it looks like the 10" subs cutout diameter range from 9 1/16" to the 9 3/16" for the 2104MM2006 SANTE 210 (Pending Sale)
