Speed Based Volume Control: HSE Revolution vs Boost Box ?
  • Mikeski
    • 2908
    • San Francisco, CA
    No but it will work if you are using the aux in to the clarion.
    I think that Wetsounds may have done this to help keep water out of the unit? I am happy my jacks are on the back because they would get broken when I swivel my drivers seat into the face of the unit. I made a separate patch panel for my system.
    • Mikeski
      • 2908
      • San Francisco, CA
      here's a pic. I have aux in to clarion, direct in to WS 420, link out from 420 (not shown), and rear out from clarion (replacing the oem aux in's in the glove box). I also have the CCAIPOD connector in the glove box.
      • Nautiquehunter
        • Jun 2008
        • 2080
        I just installed a boost box and tried it out last weekend. I couldn't be happier. It installs with an in line Y cable to the dash mounted wired remote and + and - connections. The hardest part of the installation was getting the under dash panel down. Took about 20 Min's. It works perfectly set it and forget it. Boost Box has earned the Hunter seal of approval
        • Chattwake
          • Apr 2008
          • 341
          • Chattanooga
          • 2010 SANTE 230 - Sold 2009 SANTE 230 - Sold 2008 SANTE 230 - Sold
          I've got a boost box that's sitting in the wrapper in my attic. I never ended up installing it on my 2009 SANTE 230 and my 2010 has the LINC system, so I don't need it. Someone make me an offer.
          2012 Axis A22 - on order
          2011 Axis A22 - sold
          2010 SANTE 230 - sold
          2009 SANTE 230 - sold
          2008 SANTE 230 - sold
          2007 VLX - sold
          2002 XStar - sold
          1990 Prostar 190 - sold
          www.chattwake.com
          • Nautiquehunter
            • Jun 2008
            • 2080
            Chatt I wish I knew that 2 weeks ago oh well . Anybody on the fence the boost box does to stereo what the zero off does to throttle control.
            • Braonm
              • Jun 2010
              • 7
              #21
              The Boost Box - Automatic Volume Control
              Thank you all for your vocal support of our product.
              How is the volume adjust performance of the 2010 LINC system, is it a linear increase in volume with increasing velocity or RPM? What adjustments do you have?
              I have heard that some of the 2010 boats which come with automatic volume control pre-installed are lacking the full control that The Boost Box offers. I'd just like to get a feel for how well the LINC is performing for you.
              I appreciate your kind reply.
              Braon
              DISCLAIMER - I represent The Boost Box on the web
              • shag
                • 2217
                Chattwake, How much for the Boost Box? I have a 2009 230.... Can ya help a brotha out?
                Thanks, and if your ever in Orlando, I'd be happy to give ya a pull. Private lake-boat on the lift.
                Mike
                shagit007@aol.com
                • EchoLodge
                  • Jan 2004
                  • 616
                  • Huntington Beach, CA
                  • 99 Super Sport
                  #23
                  Boost Box Q
                  I installed the boost box this past weekend. It is controlling a Sony HU. The unit works well. The only issue I have is if I use the Sony HU to raise the volume when under power (make it a bit louder after the Boost Box has raised it) the Boost Box seems to get turned off and will not lower the unit. If I raise the volume with the Boost Box it does not cancel the Box's ability to lower the volume when you pick up a skier. My Boost Box was delivered in a really worn box and it does not have the black caps on each end so I am not sure if it was a returned product or not!
                  sigpic
                  • EchoLodge
                    • Jan 2004
                    • 616
                    • 99 Super Sport
                    #24
                    Update.... Mark from Boost Box called and said my unit is new and they have never heard of my problem but assured me if I had issues they would send out a new one. I will check all my connections and see what happens.
                    sigpic
