before i screw anything up. clarion xmd3, stock clarion 4ch and kicker zx350.2
i believe the clarion has two 20amp fuses and the kicker has two 25amp. my question is, can i use 4 gauge power/ground wire into 8gauge through a distribution block? my plan is to use a 100amp fuse at the battery, but im confused about whether or not i need to fuse after the block, what size fuses or is there a block w/ fuses in it i can get? do i need a relay from the h/u to the amps? any part #'s would be awesome.
