Does any one have a diagram of how to wire a dual battery set up with a pergo switch? I think I can handle it but would like to see an example before i get in to it. Thanks
How's this? This is the best I can find on my machine right now.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Here's the one from Perko's website.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
NautiqueJeff,
I have a perko switch and just found something weird. On the standard battery there is another positive cable wired into the terminal outside of the 1/0 AWG wire. I believe it goes up to the front swtich. Now, your shows that wire hooked up to the common as well - correct? If so, does the original Nautique rocker swich offer anything, off, on, bilge? Because you always have to have at least one battery on, which then also enables or charges the entire dash - right?
My weird thing is this: I turn my perko off, but if I turn nautique swtich on, and enter my code, dash lights, up, music starts, but it will NOT turn over. If I put perko on Batt 1 (original battery) then everything works. If I put on battery 2 - and completely disconnect batt 1 nothing works. Because that extra little power cable (I think it is about 22awg) charges the fuel pump,etc...
It seems like somehow we should have the bilge wired directly to one battery; even if the perko switch is off then it can still kick in if floods. I just am a little confused of what all gets "charged" by that original nautique racker switch and how to keep things as simple as possible.
One more weird thing - if I disconnect batt 2 completely, my amp will not WORK, even though my amp draws from the common side in the switch. I am not sure about all this, I think I have some sort of backfeed. Or a bad battery - if I have all thre ballast empty pumps on at idle, my voltage drops so low the warning been comes on.... any idea's. Lots of questions and I thank anyone in advance for helping me.
