Factory Interior Accent Light LED Upgrade
  • tadelfio
    • Oct 2007
    • 172
    • Bullard, Tx
    RE: 112.5 degrees
    yeaaaa.... I'm not sure of the legality of that one. Sorry, but me personally, I would have to keep the "normal" bow light on there to keep from getting stopped.
    • wake4life6
      • Mar 2009
      • 218
      • Olympia, Washington
      RE: 112.5 degrees
      any pics of the interior 2004196
      2006 210 SAN! TE
      • swancer
        • May 2009
        • 165
        • Vestavia Hills, AL
        Re: Super Bright
        Originally posted by 2004196
        http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FSMD _LED_tube.htm
        swancer - follow the link above- I have the 7" & 12"
        on my boat (blue) and they both are plenty bright - very nice quality for the buck. Where are you placing them? - I used 12" in the side gunnels for interior light and 7" in the vent screens in the back of the boat for a little accent. Replaced the coast guard red/green navigation light on the bow and put a 7" red (port) and a 7" green (starboard) in the front scoop areas just under the front windshield for the navigation lights. Can post a few pics if anyone is interested.
        Did you use the factory wiring and switches that are in place? In other words are these lights plug and play?
        sigpic
        2005 SANTE FOR SALE (SOLD)
        1986 SN 2001 (Previous Boat)
        Smith Lake, AL & Lake Mitchell, AL
        ____________________________________
        _____________________________________
        ______________________________________
        • 2004196
          • Dec 2007
          • 162
          • University Place, WA
          • 2006 196LE
          LED's
          They are plug and play, hooked directly to exisiting wiring from the factory switch in the keypad assembly. Very quick and easy hook up and can return to stock set up just as quick.
          Wake4life6 - will try and get a couple interior shots up this weekend, where do you spend most your time on the water?
          2004 196 LE Black/Grey
          330HP Excalibur Water Churner
          2002 Grey F150 Harley
          475+HP Supercharged Tire Burner
          • 2004196
            • Dec 2007
            • 162
            • 2006 196LE
            Interior shots
            Here's a couple of pics of the blue LED interior lights, one under the steering wheel area and one of the side gunnel area.
            • SuperDave
              • Jun 2007
              • 151
              • Winston Salem NC
              • 1979 SN / 1995 SN / 2002 210 SANTE / 2012 210 SANTE/ 2016 G21
              #21
              RE: Interior shots
              Looks great.. what size did you use and where..
              2002 Super Air TE
              1995 Ski Nautique
              1979 Ski Nautique
              www.teamcarolina.us
              • 2004196
                • Dec 2007
                • 162
                • 2006 196LE
                #22
                Interior
                7" under the front dash mounted to the metal bar and 12" under each side gunnel, easy conversion on the sides.
                • Xtremeskierbfs
                  • May 2019
                  • 3
                  • NY
                  • 2005 Super Air Nautique 210
                  #23
                  So this is literally as simple as mounting them up in the gunnell and then running the wiring back to the keyad? How do they wire into the keypad for proper integration with the lighting button?
                  ELI5 please because I am not an electrician!
