Is the CMD4a a one for one swap with a XMD1 in a 01 SAN? I am hoping to swap out the head unit without having to do any major construction. Any info would help.
RE: Swap XMD1 with CMD4a
They both use the same cut-out size 7"x2", so it's a direct drop in, I think they even use the same plug, but not 100% on that. The only major diff is that the CMD4 has a smaller face, so some of the original mounting holes for the XMD1 may be visible.
I swapped the CMD5 (same size as CMD4) for the older XMD1. Used the aluminum face place purchased seperately. Worked out great. It was a bit more work than originally anticipated. Connects direct to plug and even works with older wired remote._____________________________________________
Proud2BeCC
2002 Sport Nautique
(NDT) New Dimension Tower
TowerBinimi Binimi Top
Clarion CMD5
There's no real structural issue with the change out. But the CMD is both narrower and taller than the XMD series. This only requires a cosmetic trimplate to conceal the previous four mouting screws that fall just outside of the CMD faceplate.
Here's a link to the trimplate.
David
Earmark MarineEarmark Marine[URL="http://www.earmarkmarine.com"]
www.earmarkmarine.com[/URL]
We installed the CMD4a on our 01 SAN and its awesome. The rotary volume knob is really nice because the driver can just give a quick flip when the rider is up and then once they fall they can just spin it again to lower the volume. The XMD1 is push button volume control.
we had a friend build a custom bezel for us...ordered some CF vinyl to match the factory dash but its not even close...I think we will clean it up this winter.
And our built up thread from last winter in case you are interested.2001 SAN
Does anyone know if the older remotes (M101RYC) will work with a CMD5? I was trying to determine the difference between the CMD4 and CMD5 and I found this:
The cmd5 can control a ipod if you also purchase a CeNET 1276 black box from clarion. Your ipod plugs into the 1276 and then the 1276 plugs into the CeNET port on the back of the cmd5. The cmd4 has a CeNET port but the software in the head unit cannot control the ipod.
http://www.clubsearay.com/forum/showthread.php?p=191745
I would prefer to be able to control my Iphone (3g) from the remotes if possible (at least skip to next song.)
Thnks.2008 Team Edition 210 - Black
2001 Super Air Nautique *Sold*
Originally posted by cincoThanks for all the info. Is the CMD4a going to help my sound quality versus the XMD1, or do i need to just suck it up and buy new speakers and an AMP?
Originally posted by jroyalDoes anyone know if the older remotes (M101RYC) will work with a CMD5? I was trying to determine the difference between the CMD4 and CMD5 and I found this:
Thnks.
Originally posted by EarmarkMarine View PostThere's no real structural issue with the change out. But the CMD is both narrower and taller than the XMD series. This only requires a cosmetic trimplate to conceal the previous four mouting screws that fall just outside of the CMD faceplate.
David
Earmark MarineLast edited by jroyal; 01-28-2010, 10:50 AM.2008 Team Edition 210 - Black
