How should I wire 4 Pro80s on the JL MHD750/1?
Specs
MHD750/1
Rated Power: 750 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.03% @ 4 ohm
S/N Ratio: >110 dBA below rated power
(A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 6 Hz - 30 kHz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 10.74 in. x 8.29 in. x 1.93 in.
273 mm x 211 mm x 49 mm
(Width Measurement Includes Plugs)
Might have to do some tower wiring though
You can get the 4 ohm load with the speakers you have2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
mcfr741,
Series the left two. Series the right two. Tie the left and right circuits in parallel. Your final impedance will be 4-ohms where the amplifier will deliver its full rated power. BTW, if you use both amplifier terminals, this automatically parallels.
Just wondering. Does the place you bought your amplifier from offer technical assistance?
David
Earmark MarineEarmark Marine[URL="http://www.earmarkmarine.com"]
www.earmarkmarine.com[/URL]
