ported sub enclosure question
  • 1992snob
    • Aug 2009
    • 6
    • Canada
    hey guys building a sub box for a alpine 1042d . there are a number of sites for building box's for cars that sound pressure is important however in a boat this can't be an issue . just wondering if there is a different set of rules for dimensions or just follow alpines recommendations .
  • 74green
    • Nov 2009
    • 281
    • Canyon Lake, Texas
    • 2001 Air Nautique
    I would just follow alpines recommendations like you mentioned.
    Current: 2001 Air Nautique GT-40
    • EarmarkMarine
      • Mar 2008
      • 699
      • Dallas, TX
      1992snob ,
      Provide an example of a site where the box calculation considers 'sound pressure', so I'll have an idea as to whether you're referring to S.P.L. or the loading effect of a non-compliant vehicle cabin.
      I'm at least curious.
      David
      Earmark Marine
      www.earmarkmarine.com[/URL]
      • 1992snob
        • Aug 2009
        • 6
        • Canada
        First off i'm not an audiphile , just wanted an opinion after being caught up in box design sites like this one that you almost need to be
        an engineer to figure out .
        Spl and loading as david describes are not even terms that i would know the proper definition of , sorry if I my question was misleading to
        a much larger problem than i'm having .
        thanks
        http://www.diysubwoofers.org/
        • EarmarkMarine
          • Mar 2008
          • 699
          • Dallas, TX
          1992snob,
          Okay, thanks.
          Just ahere to the Manufacturer's specs on box design.
          Go with ported if they give you the option and if this can be done in a manner where both the driver and port are on the same side and unobstructed.
          If not, sealed will be fine. The idea is to not force a particular approach. Let the boat dictate which is best.
          David
          Earmark Marine
