Out at the lake with no tower audio, im a retard... please help. Dunno what happened, I'm thinking amp is bad or something but looking for insight from all you pros out there. Tower speakers are turning on and off randomly at will, thought maybe bad connection as it was rough today so I just unplugged audio inputs so that I didnt have to listen to audio popping on and off- when I unplugged I noticed the blue power light was flashing on and off randomly so I put my head to the speakers and noticed they were turning off and on at the same as the blue power light. I'm running stock defcon IV (4 polk momos) with the larger of the 2 stock clarion amps that came from nautiques 2005 SANTE I think its a 480 (if its important i can go look). Also the cabin is running just fine no cutting out and the power light is staying illuminated. Sub's amp also illuminated and sounding fine... all get power from the same distribution block and all wires are connected and tight so beacuse the others are working i assume power in is good. About to take a mulitmeter to check if i'm getting enough power to amp, unless someone knows that the flashing power means amp is bad or that something else is wrong... ie a gain setting and over heating or something cause I messed with all the knobs earlier tonight.
Thanks in advance for any help, especially quick responses, cause im at the lake now and once i go home sunday wont have access to the boat, thanks again everyone.
