What size battery?
  • RobbieMWD
    • Dec 2009
    • 40
    What size battery?
    I have two group 24 batteries in my 2004 SANTE 210. I am looking to replace them and was wondering if I should get a larger group battery.
  • EarmarkMarine
    • Mar 2008
    • 699
    • Dallas, TX
    Yes, by all means go with a larger battery for longer playtime at rest and so that your depletions aren't as deep pecentage wise which promotes longer battery lifespan, however more depleted amp/hours in combination with your audio system draw will place an inordinate strain on your alternator and the need for a large supplemental AC shore charger
    becomes mandatory at some point. Extra large batteries are usually reserved for larger boats with twin screws and twin alternators or cruisers with large convertors/chargers. Tournament fishing boats have large banks but they're not connected to the stator at all. So you've got to understand where the dominoes fall as you enlarge one part of your charging system so that everything is in balance.
    David
    Earmark Marine
    www.earmarkmarine.com[/URL]
    • Chattwake
      • Apr 2008
      • 341
      • Chattanooga
      • 2010 SANTE 230 - Sold 2009 SANTE 230 - Sold 2008 SANTE 230 - Sold
      Check out the batteries from www.4xspower.com. I've got two D3100's in my 230.
      2012 Axis A22 - on order
      2011 Axis A22 - sold
      2010 SANTE 230 - sold
      2009 SANTE 230 - sold
      2008 SANTE 230 - sold
      2007 VLX - sold
      2002 XStar - sold
      1990 Prostar 190 - sold
      www.chattwake.com
      • core-rider
        • 1348
        • Huntsville, AL
        • 2003 Black SANTE
        If you can, yes go with a larger group battery, but if you have the same physical dimensions in your hull as my '03 does a Group 24 will be as big as you can fit. I wanted to go larger when I just recently replaced mine, but the holes cut in the floor made it impossible for anything bigger unless I enlarged the space. Measure twice, buy once!
        Jason
        All black 2003 SANTE
        -- Southern Fried --
